Realme 7 pro
terry39
Super AMOLED Fullscreen 16.3cm (6.4”) FHD+ Fullscreen
32MP In-display Selfie
Supporting Nightscape
Dual Stereo Speakers
Dolby Atmos + Hi-Res
Color
Mirror Silver
Mirror Blue
Processor
Qualcomm® Snapdragon™ 720G
Gaming Mobile Platform
CPU: 8nm, Octa-core, Up to 2.3GHz GPU
GPU: Adreno 618
AIE:5th Generation Qualcomm AI Engine
Charging & Battery
65W SuperDart Charge
4500mAh(typ) Massive Battery
Includes a 10V/6.5A Charging Adaptor
USB Type-C Port
Display
16.3cm (6.4”) Super AMOLED Fullscreen
Resolution: 2400x1080 FHD+
Screen-to-body Ratio: 90.8%
PPI: 409
Corning Gorilla Glass
Camera
Sony 64MP Quad Camera
Rear Camera
64MP Primary Camera
26mm, f/1.8
Sony IMX682 Sensor, 1/1.73” Sensor Size
B&W Portrait Lens f/2.4
Photography function
64MP Mode, Pro Nightscape, Starry Mode, Super NightScape, Panoramic View, Expert Mode, Timelapse, Portrait Mode, HDR, Ultra Wide-angle Mode, Ultra Macro mode, AI Scene Recognition, AI Beauty, Filter, Chroma Boost, Slow Motion, Bokeh Effect Control
In-display Selfie
32MP Wide-angle Camera
FOV 85°, f/2.5
Photography function:
Time-lapse Photography, HDR, Front Panorama,
Beauty, Flip Selfie, Nightscape, Portrait Mode
8MP Ultra wide-angle lens
16mm, FOV 119°, f/2.3
Macro lens
4cm Focal Distance, f/2.4
Video recording
UIS Video Stabilization
UIS Max Video Stabilization
Ultra Nightscape Video
AI Color Portrait Video
Ultra Wide-angle Video
Real-time Bokeh Effect Video
4K/30fps Video Recording
1080P/120fps 720p/240fps Slo-mo Video Recording
Video recording
Support 1080P/30fps Video
Support 720P/30fps Video Recording
Support 120fps Slo-mo Video Recording
Storage & RAM 8GB + 128GB
ROM:128GB UFS 2.1
Cellular & Wireless
3-Card Slot : 2 SIM Card + 1 MicroSD
Frequency Band
FDD-LTE: Bands 1/2/3/4/5/7/8/20/28
TD-LTE Bands 38/40/41 (2535-2655MHz)
WCDMA B1/2/4/5/8
GSM 850/900/1800/1900
Wireless network 2.4/5 GHz
802.11 a/b/g/n/ac ,Bluetooth 5.1,Navigation,GPS/AGPS, Beidou, Glonass, NavIC,
Size & Weight Height: 160.9mm
Width: 74.3mm Depth: 8.7mm Weight≈182g
Sensors
Magnetic Induction Sensor / Light Sensor / Proximity Sensor / Gyro-meter / Acceleration Sensor
Operating System
realme UI
Based on Android 10
Packing List
Realme 7 Pro
65W SuperDart Charger
USB Type-C Cable
Protect Case
Protect Film
SIM Card Tool
Important Info Booklet with Warranty Card
----- προσθήκη μηνύματος 100 δευτ. μετά την υποβολή του προηγούμενου -----
Ανοίγω το θέμα μιας και δεν βρήκα κάποιο αντίστοιχο .
Σήμερα παρελήφθη από την προσφορά του Κωτσοβωλου , εντυπώσεις αργότερα
Ας μπούνε κάποια πρώτα φωτογραφικά δείγματα... και οι δύο στοκ κάμερα (δεν κάνω πλάκα). Σοκ!!!
Η δεύτερη ειναι με το χεράτο night mode της. Αλλα και η ημερήσια τρελάθηκα... μιλάμε για κοντρα ηλιο!
50551304328_87a29d9d57_z.jpgIMG20201027163936 by Andreas L., on Flickr
50552162527_a2960e71b8_z.jpgIMG20201031212409(1) by Andreas L., on Flickr
Καλησπέρα φίλε σκέφτομαι να το πάρω εντυπώσεις;;Όντως φουλ στοκ ? Ευχαριστώ
Καλησπέρα , στα 280€ που παίζει πλέον στο skroutz αξίζει 100% (Edit: 315€ βλέπω τώρα)
Προσωπικά το πήρα από την προσφορά του Κωτσόβολου για δώρο , ήθελα να δώσω ένα P20 pro , αλλά με λίγα € παρaπάνω πήρα 8gr ram και το κυριότερο για εμένα 3 χρόνια εγγύησης , επίσης νεότερο chipset , μεγαλύτερη μπαταριά , στις κάμερες δε εχω γνώση για σύγκριση , δείγματα ανέβασε ο @Antretng , οι εντυπώσεις του κατόχου είναι άριστες , προηγούμενη συσκευή ενα huawei g8 3/32 ... δυστυχώς το phone clone δεν μας επέτρεψε να κλωνοποιήσουμε το g8 , αλλά με λίγη υπομονή στήθηκε οκ , 130+ εφαρμογές , η μπαταρία με την χρήση που κάνει πήγε σχεδόν 3 ημέρες ...
Καλημέρα και καλό μήνα!
Γενικά, εντυπώσεις από κάποιον/α που το έχει δοκιμάσει; Εννοώ πέρα από τις φωτογραφίες.
Επίσης, έχω μπερδευτεί με το θέμα του NFC. Έχει ή δεν έχει;
Στα διάφορα reviews που βλέπω γράφουν ότι δεν έχει. Στο site της Realme (Europe) όμως λέει ότι έχει, το τονίζει μάλιστα με ειδική αναφορά. Το ίδιο και στην παρουσίαση στο site του Πλαίσιου. Τελικά, έχει ή δεν έχει;
Κατά τα άλλα φαίνεται μια πολύ ενδιαφέρουσα συσκευή, ειδικά αν τελικά αποφασίσω αυτή την περίοδο να ανανεώσω / αναβαθμίσω το P9 Lite (2016) μου. Και σκεφτόμουν το Nova 5T αλλά το 7 Pro μου κέντρισε το ενδιαφέρον.
Το πηρα κι εγω με την προσφορα που βγηκε στα 230 ευρω.
Το τελικο ποσο που πληρωσα ειναι 185 γιατι το αγορασα με τιμολογιο.
Η μπαταρια κι εμενα με την χρηση που το κανω μου βγαζει 2-3 μερες ευκολα.
Καλα η φορτιση ειναι ΣΟΚ ετσι?
Το φορτιζω σχεδον παντα οταν παει στο 20% και παει για πλακα στο 100%.Για πλακα ομως ξεφτιλα.
Για τον φιλο που ρωτησε παραπανω για το NFC επιβεβαιωνω οτι εχει κανονικα.Εχει και δικη του θηκη μεσα στην συσκευασια αλλα και προστατευτικο οθονης που το εχουν βαλει απο το εργοστασιο προεγκατεστημενο.
Μ'εξπληξε ευχαριστα!Παρα πολυ καλο και με 3 χρονια εγγυηση.
Ir blaster διαθετει?
Οχι δεν έχει.
----- προσθήκη μηνύματος 91 δευτ. μετά την υποβολή του προηγούμενου -----
Αν κάνεις υπομονή να πέσει λιγο τιμή και το πάρεις κάτω από 280 τότε σίγουρα αξίζει. Τώρα στα 330 είναι λίγο ακριβούλη.
Σ' ευχαριστώ πολύ για την απάντηση!
----- προσθήκη μηνύματος 102 δευτ. μετά την υποβολή του προηγούμενου -----
Έχεις δίκιο, ούτως ή άλλως πάνω από 300€ δεν μπορώ να δώσω, ακόμα και αν το τηλέφωνο τα αξίζει 120%...
Κι εγω πανω απο 300 δεν εδινα για να το παρω,Η τιμη που βγηξε σε προσφορα 230 ευρω ομως ηταν εξαιρετικη.Επειδη μ'εχει ενθουσιασει πολυ ευχαριστα ομως το συγκεκριμενο κινητο ισως εως 250-270 να τα εδινα.Θα τα εδιβα σιγουρα βασικα.
Περιμενε μεχρι τελος του μην την black friday και μπορει να το ξαναβγαλουν αν δεν βιαζεσαι.
Δεν βιάζομαι, το P9 Lite ακόμα δουλεύει, παρά τα κάποια (λιγα για την ηλικία του) θεματάκια... ;)
Δείτε εδώ έναν οδηγό που ετοιμάζω τόσο για τη στοκ κάμερα όσο και την gcam. https://t.me/hellasmobiles/306141
Θα βρείτε κάποια τιπς για τη στοκ καθώς και κάποια xml που έστησα. Ακόμα είναι υπό δοκιμές αλλά μπορείτε να παίξετε και να με βοηθήσετε και λιγο στο στήσιμο. :)
Δείτε οπωσδήποτε το σημείο για "διόρθωση χρωμάτων". Φυσικά μπορεί να γίνει και μέσα από τις manual ρυθμίσεις, αλλά προσωπικά με βολεύει καλύτερα το φίλτρο.
Υ.Γ. Για να κατεβάσετε αρχεία θα χρειαστείτε την εφαρμογή telegram από το playstore.
Edited by Antretng
Το τηλέφωνό είναι καταπληκτικό τόσο σε φόρτιση όσο και σε κάμερα.
Το μόνο που παρατήρησα είναι ότι όταν θέλω να δω ένα βίντεο που έχω τραβήξει, μέσο της εφαρμογής "βίντεο"το παίζει καλά αλλά εάν το δεις μέσο της εφαρμογής"φωτογραφίες"δεν το παίζει το ίδιο....σαν να τρεμοπαιζει ένα πράμα.
Δεν το κάνει πάντα όμως, άλλες φορές το δείχνει καλά και άλλες όχι.
Πάρτε και δύο νυχτερινά δείγματα ακόμα.
Η πρώτη ειναι gcam hdr+ enhanced και η δεύτερη stock night mode. Να πω οτι το night mode της στοκ βγάζει ευκολότερα φωτογραφίες (χωρίς κούνημα) από οτι η gcam.
Το σημείο αυτό ειναι λίγο πιο σκοτεινό από οτι φαινεται στη στοκ.
50565029828_22f0d5183a_z.jpggcam by Andreas L., on Flickr
50565029788_7c97e0aaa9_z.jpgIMG20201103202759 by Andreas L., on Flickr
Αντρέα, ξέρω ότι κάνω κατάχρηση, αλλά έχεις άποψη συγκριτικά με την κάμερα του Nova 5T;
Δεν έχω δουλέψει το nova 5t. Επειδή όμως με ενδιέφερε για περατζάδα, έχω ψάξει αρκετά δείγματα στο διαδίκτυο. Από αυτά που έχω δεί, το realme φαίνεται να είναι αρκετά καλύτερο. Βασικά νομίζεις ότι το realme έχει OIS. Και μιλάω πάντα για στοκ night mode.
Το μονο αρνητικό της στοκ κάμερας είναι ότι μερικές φορές μπορει να βγουν λιγο πιο κοκκινωπές οι φωτογραφίες. Αυτό βέβαια λύνεται με απλή επεξεργασια (σέρνεις θερμοτητα και κορεσμο λιγο αριστερά). Προσωπικά έχω φτιάξει φιλτρο στο snapseed και απλά το πατάω όταν τύχει να το κάνει. Έχω γράψει και οδηγό σε link που έβαλα πιο πάνω (λιγο πρόχειρος βέβαια αλλα νομίζω έστω και ετσι ειναι κατανοητος https://t.me/hellasmobiles/306141). Ουσιαστικά σου παίρνει 10 δευτερόλεπτα (στέλνεις photo στο app, πατάς το φιλτρο και απόθηκευση).
Ότι έχω ανεβάσει βέβαια ειναι χωρίς επεξεργασία. Θα δω αργότερα μηπως εχω κανενα παράδειγμα να ανεβάσω όπου ηταν πιο "κοκκινωπη". Αν έχω παράπονο απο τη κάμερα είναι ισως από τον ultrawide. Πάλι καλύτερος από κινητά των 150-200 αλλα καμία σχέση με τον εντυπωσιακό βασικό φακό.
Edited by Antretng
Με βάση όσα κινητά έχουν περάσει από τα χέρια σου,στον τομέα της κάμερας που κατατάσσεται το realme;
Tcl 20 5g
Σίγουρα πιο πάνω απο mid range. Στις ναυαρχίδες θα το έβαζα. Μιλάω πάντα για στοκ κάμερα βασικό φακό και χρήση night mode νύχτα ή ημερήσιες στο αυτόματο.
Edited by Antretng
Ποια gcam χρησιμοποιείται ρε παιδιά;
Βάλτε ένα λινκ η δώστε πληροφορίες.
Έχω ήδη βάλει link με xml που έχω στήσει.
Όταν θέλετε να τραβήξετε μια φωτογραφία από την stock camera,την τραβάτε με τα 64megapixel η από εκεί που λέει φωτογραφία;;;
Αν βγάλεις από εκεί που λέει "φωτογραφία" βγαίνει με 16megapixel αλλά συγκρίνοντας τις φωτογραφίες δε βλέπω κάποια ουσιαστική διαφορά.
Ανακοινώσεις
